whats involved in removing and fitting a new driveshaft? also where can i get 1?
DJ Walkers Ibiza Cupra 247.1BHP Feb 21, 2007 138 0 Shrewsbury, Shropshire www.djwalkers.co.uk Nov 21, 2008 #1 whats involved in removing and fitting a new driveshaft? also where can i get 1?
m0rk sarcasm comes free Staff member May 19, 2001 27,787 33 Clanfield, UK Nov 21, 2008 #2 unbolt the hub nut (big big bar, 6 sided socket) undo the driveshaft to gearbox flange bolts undo the bottom ball joint to wishbone bolts remove easy peasy (once you undo the hub nut)
ibizacupra Jack-RIP my little Friend Jul 25, 2001 31,333 19 glos.uk Nov 21, 2008 #3 driveshaft bolts being spline drive @ gbox end
m0rk sarcasm comes free Staff member May 19, 2001 27,787 33 Clanfield, UK Nov 21, 2008 #4 ibizacupra said: driveshaft bolts being spline drive @ gbox end Click to expand... and easy to mash if you use a cheap tool
DPJ ........... Dec 13, 2004 7,996 2 NN Yorks / Salento www.seatcupra.net Nov 21, 2008 #5 m0rk said: and easy to mash if you use a cheap tool Click to expand... ..and are really one-use, you should always replace with new ones.
DJ Walkers Ibiza Cupra 247.1BHP Feb 21, 2007 138 0 Shrewsbury, Shropshire www.djwalkers.co.uk Nov 22, 2008 #6 thanks guys any suggestions where i can get 1?
