driveshaft bolts wtf
Ash-Kennard
why are you reading this?
Jul 31, 2008
286
portsmouth
ok, they're not allen or torx, they are finer than torx, any ideas? i need to take the drive shaft out to undo the last bolt on my sump.
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
Make sure you use locktight or a similar thread locking application on the bolts and make sure there tight as they can come loose, happened at work a a v6 galaxy bolts came loose even tho they were torqued up to the correct torque, came loose and driveshaft end smashed through the gearbox casing, wasnt pretty so just double check :)
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
You need spline bits! M8 if I remember! :)
Better get new ones from the dealer because I rounded everyone of them before!
Flaper got a ford part number for allen bolt ones instead.
