Drivers Door
May 18, 2023
had the formentor since new May 2022, gave it its 1st wash (carwash until now) and noticed this bolt. It's the drivers door, is this normal as it looks out of place.
Thank you in advance
ChrisGerr
34
34
It is meant to be there but you are missing a rubber cover / cap (you can see the outline on your picture.
Chris
Sep 13, 2024
Hi - I have the same issue - Marcus - did you manage to find a replacement? If so could you please provide a link?
Sep 9, 2024
10
Hi,
Was your door ever damaged in an accident for instance?
If so, it could have been poorly reassembled by the mechanic? :unsure:
Otherwise, maybe they forgot to put some kind of loctite on the screw thread upon assembly. Vibrations did the rest...
