Drivers Door not unlocking when removing Key
Woo
Good afternoon all
wondering if someone could help me.
when i remove the key from the ignition the drivers door should unlock yes, well it used to.
Now it doesn't, if i take the key out, giggle it about at the lock it usually does unluck.
Now this only seemed to start happening since I changed the head unit, no wiring has changed, just plugged a new one in.
Also is there anyway you can disable the auto lock function?
Woo
strange thing is, it wasnt astandard HU that was in it to start with , it was a Pioneer, and i have put a Sony in
EdButler
713
Sheffield
Youve wired the Switched and Constant battery feeds the wrong way round...
The Red wire from the car goes to the yellow wire on the Head Unit connector and vice versa. That should get it working :)
