Drive Shaft balance weight. (replace?)
chrisbond69
chris bond
Jun 11, 2005
1,297
Cirencester, Glos
Ive done a search to no avail, i have on my side two drive shafts which im wanting to send off to powdercoating but the drivers side item has that stupid rubber weight is in the way
1. any suggestion on how to remove it if it can be removed
2. any idea on a part number
3. should i just get it painted and mask off the rubber?
also whilst im on the subject how much roughly would i be looking for a new drivers side inner cv joint and bush kit,
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
powercoating will melt it
mine are removed completely, not adverse effect.. you need a cutting disk
chrisbond69
chris bond
Jun 11, 2005
1,297
Cirencester, Glos
ive found a part number for it on the item itself, whats the purpose of it then, the number is 1H0 407 294 I wonder if it can be replaced how is it fixed to the shaft please bill?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
mine have been rusted onto them... clamped but rusted beyond undoing, and there was a metal sleeve bonded to the rubber.
Its not a balance as such but a harmonic damper I think to take resonant frequencies out.. along the lines of that 5kg weight bolted to the subframe.. :banghead:
