Danwheeler2k11
mellow yellow
Jun 3, 2011
130
Anyone know where i can get a set of drilled and grooved discs all round for leon fr 170 the cheaper ones not expensive ebc ones on there own without pads? Cheapest ive found is £180 on ebay but with pads cant find them on there own ?
I can recommend MTEC discs. Got them on my Alfa and they're just as good as the EBC or Brembo discs IMO at a fraction of the cost. If you look around, they generally get pretty good reviews.
MTEC used to sell through an outlet on eBay (I've not checked if they still do) but you can also order direct from their website...
http://www.mtecbrakes.com
Ye ther the same as the set on ebay with the pads but you can buy them on ther own of that site nice one for that
Don´t get drilled discs, more so if you don´t track the car and do regualar cleaning off the discs. Its only a weak point on the disc and will most likely just micro crack at those drilled holes first, making the disc more and more fragile. If you buy drilled discs for big brake/OEM kits that cost $$$$, they are cast with the holes in them. Discs as MTEC and all those cheap makes are taking blank discs, and just drill through them. Only one way that can go and thats down hill. If you go to a race track or something like that, look at what the people are using for the track, its most likely slotted discs, and if they are drilled, you can bet it has cost the bomb^^
