I was trying to fit my exhaust today and cant see a way of getting the dp out from the car
I've undone the bolts from the manifold but when i try and wiggle it out it wont go as its tight against the steering column at the back of the subframe.
Do i have to drop the front subframe and swing the steering rack down to make more room (i've already undone the bolts and drained the power steering fluid to make more room)?
Or is there another easier bit that needs to come off before i can get it out?
- we cut lower mount arm on the downpipe and eventually with patience found a angle and a path to get it out from underneath
I'll give it another bash tommorow. I have to admit after spending about 2 hours swearing at it i started looking at the exhaust cutter thinking hmmmm
Then i remembered the amount of time it took to cut the backbox off and figured it would be thicker at the DP (bet it's ace on pizza tho).
followed by what seemed like the gasket on the manifold blowing
Luckily it hadn't taken the thread off so i just screwed it back in. I have some before and after logs to post when i get in, but does anyone know what this sensor is for and how it managed to force itself out when its threaded?
