Hi All hope you may be able to shed a little light on this one?
My drivers door unlocks when I remove the keys but when I pull the handle it only opens half an inch or so (like when you don't shut a door hard enough and it locks but rattles and won't open or shut). When I let go of the handle and pull it again it opens the rest of the way every time.
It also does the same when you unlock it from the outside, opens a little then all the way when handle is pulled for the second time.
I'm pretty sure it only does this after being locked and doesn't do it everytime but it appears to be happening more often.
Is it a something easy like a stretched cable or some lube needed or am I gonna be shelling out for a new lock
Thanks in advance
Tom
Thanks in advance
Tom
