Hi Everyone,
I have a 64 plate Leon FR 184. A few months ago the drivers side wing mirror stopped folding in when I held down the lock on the fob for 3 seconds, it also won't fold with the switch on the door from the inside. The mirror adjustment part of the switch inside still works.
Took it to my mechanic who said it was a fault with the door module, he apparently plugged it in. His quote to replace it was ridiculous so I decided to try and get hold of a genuine second hand one and replace it ourselves. The replacement is visually identical with same part number.
When we replaced it (which was relatively simple) the drivers side door would not lock, with either fob or key! Tried the folding mirrors, this did not work either. Should we have disconnected the battery or done some kind of re-set after replacing the module? Has anyone replaced the door module before on a MK3?
We have put the old module back in for now. I think we need the replace the whole wing mirror myself so might try this as a second resort.
TIA
TIA
