Door Control Module
JeffJeffers
:confused:Hello,
If anyone could help me with some advice for the following problem I would really appreciate it. I've done a search but I just want to be sure!
Car: 1.8T Cupra 51 Reg
The central locking has failed on the passenger door, after searching through this site for help I have purchased a VAG-Comm cable and have run a diagnostic which has come back with 2 errors:-
1. 01332 - Door Control Module; Passenger Side (J387)
49-00 - No Communications
2. 00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-00 - Implausible Signal
When I press the remote button on the key the door locks then immediately unlocks itself.
I have taken the door panel and have disconnected the power to door so that I can lock it. Is this just a simple case of replacing the 'Door Control Module'?? If so, I take it the central locking won't need to be re-programmed to the new module:confused:
Cheers:)
