door cards issues...and some other little things...
scarfacetf87
BARI (ITALY)
www.myspace.com
hi to all :)
I've a very bothering problem with door cards...when I pump up the volume of the stereo...door cards make annoying vibrations...there's a way to fix this problem?? replace the plastic holders of the doorcards with some other things??
I can change door cards with mk3 version?? This can be a solution?? I haven't found an how-to guide in the forum to fit mk3 panels in a mk2...(by the way I know how to remove doorcards...)
Another problem is that...if I pull 3/4 times the external handle of the passenger door with lock inserted...the door will open anyway...I've already fixed the rear door that don't opens...but the front door locking system it's different than the rear... (I haven't central locking)
I've forgot...when i start...I hear a vibration from the glove box...HELP MEEEEEEEEEEEEEEEE I HATE VIBRATIOOOOOOOONS!!! :D
p.s.
I've already said excuse for my english in presentation section :p
P.p.s.
Yes...yes...I've also got pedalbox problems (squeeking clutch pedal...) :)
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
MK3 door pannels are a straight swap but don't expect this to stop the rattle's it'll only give different ones!
Glove box is common, check to see if you've lost one of the rubber studs from inside the box door, this should cure it.
scarfacetf87
BARI (ITALY)
www.myspace.com
thanx a lot cupra kid...I'll check the rubber studs in the glove box door...btw...what's the meaning of straight swap?? :confused::blink:
welcome to the squeeky world of seat ownership
:D
lol xD
scarfacetf87
BARI (ITALY)
www.myspace.com
no one can help me with the other things?? :(
btw, the vibrations don't come from the glove box under the steering wheel...but from the glove box in the passenger side.
p.s.
3 days ago my clutch cable was snapped...130€ from seat: brand new clutch pedal and cable...and i have to change the clutch too...400€...
