davidol said:just try to take it to 6500rpm alex, if it wont make it then fair enough but like phil's said, it will provide a much more accurate picture as to whats happening
andycupra said:or due to the coil pack the car has backed off...
just change the one coil pack and reset it.
Revo Kev said:If the turbo was gone then no doubt you'd be going through oil like there's no tomorrow, or the car wouldn't be running. Replace the coilpack, reset the ECU then get someone to log the MAF values, Requested and Actual Boost and Load... 002, 115, 114. I'll have a look at it if you're ever in this neck of the woods!
CupraTgirl said:I will check my oil tonight, i had my 60,000 mile Service done about a months ago and they did an oil change then so should be ok
I dont know if the garage will reset the ECU once they have fitted the coilpack? Surely thats standard?
Where abouts are you again?
Cupra 200bhp said:How much was it for your 60k service? Im nearly due one lol
Saul said:on kevs behalf, he is in daventry, northants, cannily enough this info can be found on www.revotechnik.com
CupraTgirl said:I had the 60,000 mile Service, Cambelt, Tensioners & Water Pump done for £405
Cupra 200bhp said:Thanks for that...! Thats the sort of price i was expecting £350-£400, will get it done when i come back my hols
Cupra 200bhp said:also just change the two coilpacks....saves any hassle! You probably know they are under warranty for 5years
CupraTgirl said:They have got new HT Leads on order and a new coilpack as number four is misfiring apparantly although they said i should have them all replaced together but that would be over £100 so they have just ordered one at the moment
Jonzy said:ht leads eh.... wonder what they gunno do with them?
