does this mean its misfiring?
DJ Walkers
Ibiza Cupra 247.1BHP
driving car today and suddenly went into limp mode and struggled like no tomorrow! sounds like a tank i presume its misfiring this is vag com read out
Address 01: Engine
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 G 0002
Coding: 10500
Shop #: WSC 47688
6 Faults Found:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 -
17832 - Secondary Air Injection System; Bank 1: Leak Detected
P1424 - 35-10 - - Intermittent
17968 - Maximum Engine Speed Exceeded (Engine Warranty VOID! :)
P1560 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-00 -
Readiness: 0000 0000
seems to be on cylinder 4 is that just a case that the spark plug not working?
and help especially with pics would be greatly appreciated
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
sounds like a coil pack gone! you'll need to move your charge pipe out the way to get to 4, unplug the coil pack and pull upwards on it and it should eventually "pop out"
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
well, just to check its only the 4th, id start the car up and pull each one off, if it makes it run rougher then that one is ok, and so on, the 4th one is the one on the far right, you have to take the charge pipe (aluminium pipe) that restricts you from changing it.
DJ Walkers
its all part of me buying a car! i buy a car it breaks simple as lol :)
so am i right its the one you can just see in that picture?
cheers mate your help is greatly appreciated :)
