Does the Leon eat light bulbs?
Maximus2000uk
My FR has been through more new bulbs than I care to count! It seems that one of the bulbs blows at least once every 4 months.
Am I alone in this phenomenen?
marc8898
it seems to go in a pattern for me, right headlight, right side light right tail light, right brake light, then left taillight, left brake light and so on
dave.richmond
122
so far in six months i have had two bulbs blow, first it was the right front dipped beam followed by the rear left tail light. i wonder how many more will go in the next 6!
ghosty
251
essex
no probs here, still using the same bulbs for the past 2+ years
im sure you know when changing bulbs that your not supposed to get any grease or fingerprints on the glass of the bulb itself as that could reduce its lifespan, just a thought
Maximus2000uk
I always buy new bulbs from a 'power' company online. I always buy Osram so its not the quality of the bulbs, and they're always fitted carefully and cleanly
claudefrog
683
At home
www.reallymeansounds.com
brake bulbs?
I see you have a DSG box from your sig..
friend of mine has an Auto, and he is always blowign brake bulbs.. reason for this is he sits on the brake pedal at lights instead of using the handbrake or putting the car in neutral.. he started using neutral and handbrake and no longer has the problem
My missus used to have an Audi A4 (also vag, of course) which always seemed to be moaning about one or other of its bulbs. I remember once it got through three rear sidelight bulbs in two weeks. We thought it must have some sort of fault but the dealer could never find anything wrong with the wiring etc. It was a company car so she just got rid asap when its mileage cap was reached.
My FR (DSG) doesn't seem to have the same problem. Had it since June (I think) and the only bulbs I've replaced have been perfectly fine and replaced out of choice for aesthetics! ;)
Jace
Sneaker Freaker
Replaced the dipped on both sides in the past month, both Osram Nightbreakers, replaced with the same.
I think they had been in about a year or so, but I do a lot of driving in the early mornings & will always have my lighst on once it starts to get dusky, so I kind of take it as thats the way it is.
Not replaced any other bulbs though
For me in 1.5 years.... i'm constantly changing front fog lights h3's, replaced driver side brake bulb twice, sidelights (now cured with LED bulbs) and now I've my drivers side main bulb out and really can not be bothered to change it, I'd rather just use my horn.
Anyway I'm going to just LED up my car which is just about possible for everything except the full and the dipped. Might get some HID's and projectors fitted to avoid the filament lamps.
Feb 26, 2009
5,275
Wolverhampton
An excessive number of blown bulbs suggest a possible alternator or voltage regulator issue, higher volts causing higher amps causing 'pop'.
My mates Golf used to go through rear bulbs, but they used to go smoky rather than blow? Apparently that's a common problem with Golfs though.
I've only had to replace a front bulb, gave me a reason to fit some decent lights...
OLDOILER
1,292
Wiltshire, UK
If it is the performance mains lamps, check the small print on the lamp box - it does state that high performance lamps do NOT last has long as standard lamps !!?@@!
Maximus2000uk
You've sort of missed the meaning of the way that the word 'power' has been used. It is there to ensure people understand where I am buying the bulbs from, namely a very well known and well established company.
I state which bulbs I am using in my sig.
Jon TDI
Eat My Soot!!
Apr 28, 2003
1,518
Round the twist.
Nightbreakers don't last as long as normal bulbs. A few owners on Briskoda are complaining that they are blowing too.
There's an old saying - "The light that shines twice as bright, lasts half as long".
Maximus2000uk
The Nightbreakers are guarenteed with the company I use, so I have sent them back a couple of times when they have blown and receive free new ones direct from Osram which is handy.
The bulb issue however, is not just on the front lights hence my concern.
