I'm getting a bit desperate here folks, as I don't have an MOT pass and my tax is due end of this month.
Basically the dealer diagnosed a fault with the N75 valve. I've now obtained a new N75, thanks to a local VAG parts specialist. Question is, do you reckon this will cure the emissions problem? In the event that it doesn't (I'll find out on Monday) what else can I try to fix the problem? It failed because the lambda reading was too high.
I have 0 confidence that the dealer knows what they are doing. The car is going into a small garage Monday to replace other mechanical items, but he's not a VW specialist. There was an advisory note on the MOT about the exhaust box rattling, which is going to be replaced.
Any suggestions/advice much appreciated.
