Hey fellas
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297 - 35-00 - -
17545 - Shareware Version. To Decode all DTCs P1137 - 35-10 - Please Register/Activate - Intermittent
17535 - Shareware Version. To Decode all DTCs P1127 - 35-10 - Please Register/Activate - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent
16486 - Shareware Version. To Decode all DTCs P0102 - 35-10 - Please Register/Activate - Intermittent
been getting slight idle problems, finally got it plugged into chinese vag com today... we reset the codes and they didnt come back on, but then the idle problem has only just started and isn't 'real bad' there isnt a noticable drop in power and no engine light on or anything....
we checked for leaking hoses etc and the idle problem stopped with the maf unplugged.. the dump valve was replaced by the previous owner less than 8k miles ago... that last code really has me thinking its a dodgy mass sensor though?
