do i have a problem now?
dippy4000
going faster
Feb 14, 2009
157
Kent
i was checking the oil this morning and as i pulled the dipstick out anad the tube shattered (i presume where its so cold). a piece about 10mm x 3mm has gone down and i'm now unsure what to do. Is it a case of getting the oil out now without starting the engine as not to cause any damage? if so and it doesnt come out with the oil then what next. last thing i need right now is the thing blowing up on me!
nicksxjr
Revo....whiplash!
Jul 24, 2009
254
Somerset, taunton
if it were me i would drain the oil now to be sure to get it out.
the worst thing that could happen is it may get caught in an oil feed and seize a part of the engine.
having said that it will more than likely just get caught in the filter and you will be ok.....
JamJay
California Bound
The tube goes down to the sump so if you want to be safe, drain the oil, remove the sump and the metal bits inside and refit. You will need a new sump gasket though but I am unsure if this was sealant or a specifically made gasket.
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
note sure mate , but this happened to my mums clio derv , but hers is plastic dipstick so presume it melted in the meantime , where as mine at least is metal , would imagine the internals would chew it up but obviously not goig to do it any good
can you not look at getting a telescopic magnet to reach down there to retrieve it
nicksxjr
Revo....whiplash!
Jul 24, 2009
254
Somerset, taunton
magnets dont stick to plastic.........:p
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
The dip stick tube is plastic, this happened to me, i found a part in the sump when i changed my oil pick up after about 12 months i didn.t realise anything had fallen in, replacement is about £7 the bit will sit in the sump as it cant get passed the pick up .
dippy4000
going faster
Feb 14, 2009
157
Kent
Looks like thats what i'm going to have to do.
thats easier said than done for me, i dont even know where the sump nut is lol, i normally pay people cause im no good at this sort of stuff, I CANT EVEN CHECK THE OIL WITHOUT CAUSING A PROBLEM :wtf: better get leaning and buy some ramps i suppose.
dippy4000
going faster
Feb 14, 2009
157
Kent
PHEW thanks for that, getting the tube now then off to the garage for an oil change.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
It's not a gasket, it's just silicone sealant
