I've just had a 105bhp head put on my 130 block, obviously had the 130 injectors put in the head but never changed the glow plugs because the head is quite new.
Now it sounds like i'm starting the car on ancient glow plugs...like when you turned the key on old diesels before the glow plug light goes out lol. Then it'll start after a bit, and if I stop the engine then start again, it'll be fine.
The old glowplugs always start fine so i'm assuming they were a match for the injectors??
