Recently decided to throw out the standard rear speakers of my 02 Ibiza MK4 as one had blown..
I picked up a a pair of FLI 17cm 220W components from Halfords (which i know to be generally good), and drilled out the crappy riveted speaker brackets, placing the speakers in MDF and bolting in (as many have done)...
When i installed them, i realised the standard H/U amp didn't have enough power to drive them properly, so they couldn't be heard, so i picked up a 2 channel Mutant amp..
My dad wired it up (an electrician, but not a car audio guy, which is why i am suspect of the wiring), and we tried again...
The speakers are definitely loud enough, but to be honest they seem far worse than the ones in the front, distorting almost completely when turned up to a decent volume, while the standard paper fronts play totally clear. I have put AntiVibe sound deadening on the panel behind, an theres foam insulation already in the cutout.
The cones also seem to jump like mental even at low volume, vibrating all the panels ( when in the shop they barely moved about, no matter what volume or bass)-
This is as well as horrid alternator interference, which i've been told can be cured by rigging some sort of capacitor to the power lead from the alt.
Anyone any ideas why it's so bad? these speakers were nearly £50, and as i'm not pumping massive db's, i thought they would be decent...
