Disconnecting battery ?
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
I have a 2003 lcr with a eml on.
presuming these are progressive ecu's will disconnecting my battery for a hour clear all faults ???
also if i remember rightly the alarm goes off when battery is disconnected is there a way around this ???
adm013
197
Edinburgh
Howdy, the alarm will only sound once you reconnect the battery, just do the usual lock/unlock to stop it once connected, or pull the fuse on the horn will you play about with it and that way only the hazard lights will flash. Not sure about the ECU....sorry didn't really answer your question....:blink:
D.K
LCR 225
Oct 24, 2007
6,408
se london
You would be better off puting VAG-COM on it to find out what the fault codes are and then clearing them
