dint in my front wing
j.cavo
8 valves of pure power
Aug 6, 2009
229
Liverpool
anybody no how hard it would be to get a dint out my front wing its fairly large and looks like its been caused by some1 pressing hard on the pannel
i think i could push it out but would i need to pull the wing off or could i get my hand behind the pannel and push it out not sure if its double skinned
any help/info would be a life saver
cheers
jay
Aug 24, 2007
800
any pics mate ?
Got to try and pop a dent out of the mrs mk2 tomorrow as it happens :(
j.cavo
Aug 6, 2009
229
Liverpool
ill get 1 the cars up my mums path but im going there in a few hours i noticed it this morning but didnt have they key on me to have a look but ill see how it goes if i cant pop it out ill get some pics uploaded
just not sure if there double skinned or not
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
The front wing isn't double skinned...... could give a dent removal company a shout. The things they can do is amazing.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
if its not creased and cracked paint then get the liner out and push it back by hand
j.cavo
Aug 6, 2009
229
Liverpool
Had a ago at sorting it you cant see the dent in any pics but its large like its been pressed into the pannel.
I tried poping it out by hand and it did improve it slightly but i think ill have to use a suction cup or take the wing off.
Cant work out how its happend as the car was on my path.
j.cavo
Aug 6, 2009
229
Liverpool
I take it the liner was the plastic sqaure glued in the wing it was snaped as the dint went right over it
so i think some divvy has booted the wing jealous fu*kers [:@]
any pics/diagrams of the wing so i can see how take it off (ie how many screws or bolts hold it on) as i cant get no pressure on it when put my arm in to sort it
cheers
r1k1
its a bolt on wing on a mk 2 sooo i think its the bolts you can see under the bonnet undo all of them theirs 1 behind the mud flap annd maybe 2 behind the bumper... before you try that use a plunger like out of the bath room their just as good as suction cups. if you use one bring it out slowly and it should work ... hope this helps... rikki
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
