Diesel Rhino additive?
davepenn
28
teesside
hi guys ive been reading a bit about Diesel Rhino additive and heard some really good reviews i usually use Stanadyne Performance Formula Diesel Fuel Additive but was considering trying something else?
has anyone been using rhino for there seat and if so did you notice a difference?
many thanks
kr1s77
203
Birmingham
I'm on my second tank using rhino diesel. I must say I noticed a change from after driving 6 miles after putting 150ml in the 50 litres I filled up with. First it started to feel more responsive with the turbo. After about 20 miles on the same journey, I noticed that it was idling and driving smoother. I noticed yesterday that the turbo pulls better now, so I hope that it is decoking it and that it is not all in my head lol. I would recommend it, even if it is just to try one bottle. At about £24 its worth a try.
Interested in the sounds of this, sorry to hi jack but what have other people used and found best? I have a pd150 never used anything like this on my car before as I thought it may knacker injectors up or something.. Somebody give me reasons not to believe this and get it out my silly mind
STU3Y
1,271
Kent
It is designed to clean injectors etc, these products are scientifically tested and researched before release and they wouldn't get approved for sale if they damaged things. I only discovered diesel rhino whilst reading a few threads today, and seems to get outstanding reviews even from the sceptics who have since changed their minds after use. One guy even claimed to have gained 60 miles per tank after long term use, which is the only way you will see real benefits. Plus its cheaper than using v power fuel etc.
STU3Y
1,271
Kent
Wow ordered diesel rhino late night on 23rd arrived this morning. Can't use it yet as need to fill the tank up, but will update as and when I do<br/>
Where do you get this stuff from? Yet again as my injectors have a pressure of 30000psi it wont damage anything with it I've heard you can only use certain stuff for certain engines...
STU3Y
1,271
Kent
Just google diesel rhino they have their own site. If you look up google rhino discount youll find a forum and can click one of the manufacturer images to get 10% off
STU3Y
1,271
Kent
So added rhino today for the first time, first note, it stinks like mad and is so strong its hard to shift the smell if it gets on anything so don't spill any and don't get it on your seats. I've done a 100 miles today so far and do actually think the engine tone has changed ever so slightly, it seems a bit deeper but quieter. The engine feels slightly smoother too, and this is most noticeable by the reduction in vibration through the accelerator pedal. The biggest thing I have picked up on which I think is partly how busy then roads are today but for most of my journey I only had to apply the smallest amount of pressure to the pedal to get the amount of drive required which seemed far less than normal, I'm talking mm's of pedal travel to the point my leg wasn't used to the position so my muscles were twitching adjusting to it. Also today I saw 43mpg on the average trip for the first time ever. Its too early to tell if it will make many real difference but I am hopeful and will update with any findings in a few tank fulls
sockpuppet
837
I just bought some of this stuff, it has the rancid smell and the bottle leaks just like millers! To early to see any improvement as I'm still on the first tank of treated fuel.
Before I got diesel rhino, I did do a bottle of millers and used the esso premium diesel for about 5000 miles and it has improved the performance a little.
STU3Y
1,271
Kent
Just finished my first tank, compared to my last two tank fulls I am up 3mpg and got 10-20 miles extra. Will continue to update until the bottle is gone<br/>
sockpuppet
837
I finished my first tank and got 575 miles which is way better than the 520 - 530 I normally get from a full tank. Should have the results of the 2nd tank next week.
STU3Y
1,271
Kent
What engine and type of driving do you have. I only got about 485 or something which is the most I ever had. However for the first half of the tank I was 60 miles up but then did some runs trying to log data on my obd2. So seemed to lose loads
sockpuppet
837
I have a standard 150bhp, 10% of my driving is round town, 50% dual carriageway and the rest is country roads. Driving style "spirited"
