Hi guys
Basically my car is f***ed..at times.
I will be driving along and everything is fine but then randomly I will get like a jerk and the ESP light will come on. I think it's esp, will have to double check this. First time it happened my pipe came off the standard dv as I forgot to cable tie. Put it back on and it was fine after. Then changed over to a 007p and it ran nicely with this. Then a few days later my exhaust flexi started blowing quite bad but car was still running fine.
Then it happened again about 2-3 times now. The car jerks a little and the ESP light comes on (sometimes the engine management light too) then will struggle to start. I scanned it and a few times it has brought up the speed sensor error. G20 I think? The camshaft retard setpoint or whatever it is also has come up once or twice.
Now the worst bit...
This has happened second time now..the other day I was driving along and luckily was driving quite slow and went to brake and there was nothing there what so ever, the brake pedal went straight to the floor. Manage to bring the car to a stop by lowering the gears and eventually using the handbrake. Immediately turned the car off and then noticed smoke coming from the engine bay, from the driver side near the brake fluid bit. But I couldn't actually see what was wrong. Had a look at everything and couldn't see anything wrong. Then once it stopped smoking I pressed the brake pedal a few times and it seemed normal again. Started the car and it worked fine.
Got home and scanned it and brought up an error under 'abs' bit. Can't remember what it was now. Reset it and all was fine but then again today it happened. No smoke this time though. Just a jerk esp light came on. Car wouldn't start and had no brakes. Scanned it straight away and it came up with an error about the brake sensor. (Abs sensor I think?) after a while I reset the codes and the car started and it runs ok.
Now the car is going in the garage to get a new downpipe fitted on Saturday but I don't believe that the fault codes are all linked to the blowing flexi or am I wrong?
It is a leon cupra r with a stage 1 remap, a forge 007p and the n249 valve has been bypassed. Other than that it is standard. Now when I bought it, it was already remapped by the previous owner and the valve was also bypassed. I'm thinking that it is a **** map and needs looking at but it still shouldn't be behaving the way it is should it? Especially the brakes. Also the bypass looks a little dodgy to me and I've read all the guides and everything but can't make sense of it as I think he's removed a few too many things.
Any help is much appreciated. Any heads up on what to check/replace.
I was thinking of getting a speed sensor and abs sensor tomorrow and changing that but not sure where they are located?
Someone please help! Thank you.
If anyone is local to me (West Yorkshire, Huddersfield) and can take a look it will be much appreciated.
