jaymd
77
Macclesfield - Cheshire
I finally got round to fitting my density street mounts on friday but i am not sure if i have a problem somewhere now.
For the people who had these fitted did/does your car sound slightly different after fitting these.
I have a slightly odd noise when setting off which i think could be the exhaust either vibrating on something or just the tone of it has changed.
Any help before i have a dig around the engine bay tomorrow.
itll be the decrease in pressure on the exhaust system mate, totally normal....
make sur the bolts are torqued coorectly mind, as a little vibration will be felt if this isnt the case.
Did you use the bolts Issam gave us or the OEM bolts?
You will notice a slight difference due to the engine not slopping about so much
