I know there are a lot of guides on here regarding the wiring/install of oil temperature gauges and I've read through most of them.  I just had a few questions about installing the one I've just bought off Ebay from Demon Tweeks.
The back of the gauge appears to be similar to Craig LCR's - http://www.seatcupra.net/forums/showthread.php?t=223029. From what I can see my connections are the same - S goes to the sender, - goes to engine ground and + to ignition switch. I then have two wires for the display, black and red.
The below diagram is what was received in the box
The red wire is positive, so I guess this goes to the fat red wire on the light switch block? Where would the '+ ignition switch' wire for the sender go to? I also don't appear to have a switched live wire to control illumination with the headlights, is that missing? Would the black wire for negative at the top of the diagram go to brown in the switch block?
I'm basing the assumptions on what's in http://www.seatcupra.net/forums/showthread.php?t=223051 and http://www.seatcupra.net/forums/showthread.php?t=119724&highlight=wiring+guide
There were also four adaptors included and from what I've read I need the female 1/8NPT to male m10x1. I'm not sure if that's what one of these are. The sender seems to fit in all of them, but when I try and screw it in I get resistance about half way and don't want to force it any more. Am I better off just buying a new one? Not sure if the thread on the adaptors or sender are a bit dodgy.
Any help would be awesome!
Cheers,
Dave.
Cheers,
Dave.
