Decieving Oil Reading Too Much Oil Help!
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
After getting my LCR i checked the engine after leaving it still for 4 hours and the oil level was non existant on the dip stick! So i poured in 2 litres of oil that i had to keep it around the medium level. After checking it 30 minutes after i added oil the level was just over half way. 4 weeks later today showing the misses how to do her "show me, tell me" for her driving test I got her to check the oil! After wiping it the stick and pulling it out again the level was atleast a quarter over the MAX! Sounds impossible! But would this cause any engine damages?
Apr 24, 2007
985
W. yorkshire
I had this the other week.
It will cause some degregation of your cat but no real damage to the engine.
It will just burn off the excess oil
andycupra
status subject to change
was the reading taken after the car was at a standstill for a long period?
for engines abouts this size id not receommend putting in 2 litres at a time, but then im sure you dont need telling this now.
Now, this is where you may feel a bit better:
The dip stick has a shaded area to indicate the prefered volume of oil. Above and below this (if i remember corectly) there are folds in the dipstick.
After looking into this for previous similair questions i did find some information that indicated that the shaded area idicates the recommended min and max levels, but the folds are the outside and actual limits. But with no margins. Therefore if you are within this range you are probably ok, however id still recommend losing a bit.
However you could have burnt a bit off and it was even higher at some point!
Other things to check are:
Is it possible you did not use the dip stick correctly originally? ie you pushed dip stick in but not fully, perhaps the handle of the dipstick was not aligned correctly with the tube and therefore you got a false low reading?
Or is the dip stick ok? sounds funny, but is the handle not loose?
Or.. where the readings taken on level ground on a cool engine?
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
Sorry i got it wrong it was 1 litre. The car was stand still for about 4 hours when i seen the reading empty. When i checked again this morning the hadnt been used for over 9 hours. It has been cold both times i checked.
How i check the oil...
1. Park the car on a flat level.
2. Leave it 3 hours or more.
3. Make sure the dip stick is pushed all the way in.
4. Pull out the dip stick and wipe the oil off.
5. Put the dipstick back in all the way.
6. Pull it out again and check the level.
7. Repeat step 3-6 for accurate reading. (if the oil is topped up i repeat all this again in about 30 minutes)
