de-pressurising fuel system
andyj
There's no F in Quality..
Anyone got any idea of the correct method of de-pressurising the fuel system on the Leon?
Need to change my fuel filter tomorrow morning, as it's split. So I need to de-pressurise the system to stop petrol p1ssing everywhere when I disconnect the filter !!!
I know on the Mk2 Ibiza you remove the fuel pump relay, and turn the engine over.
Probably something simialir on the Leon, but not such which relay is the fuel pump one ;)
Andy
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
do as I do, pull each relay in sequence, turn the igntion - when you can't hear the fuel pump - you've found it
andyj
for future reference, the fuse panel on the Leon is in the right hand end of the dashboard !!
had to get the manual out to find out where it was !!!
the fuel pump fuse is number 28. There's a list in the manual, and then a diagram by the fuse panel identifying the fuses !
Only took me about 30mins to do the whole job...
