Dashboard dial removal
Jan 13, 2008
32
Midlands
Could anyone tell me how you remove dashboard dial binacle thingey , the bit with all ya dials , rev counter speedo etc . I am determined if that helps lol. have some mods to do an need it out ? Thanks in advance .
basssound
286
Rotherham, South Yorkshire!
From what I can remember.
Remove the steering cowels, one screw under the colum adjuster handle and two screws from the top, can't remember if the steering wheels has to come off?
Then you can see the two screws holding the plastic in around the edge of the cluster.
Remove that trim and you'll see the screws holding the cluster in, infact yeah the wheel does have to come off to get the cluster out.
Also the airbag comes off by inserting a screwdriver into the two holes at the back of the wheel, lever to tabs that you will feel and the bag pulls out.
Make sure you've disconnected the battery and left it off for 20mins ;)
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
There is no need to remove the steering wheel to remove the instrument cluster, just move the steering wheel out and down to make more room and it will be enough.
