Dash Bulbs
Mackers
Part Man, Part Metal
May 17, 2007
249
Bangor. N.Wales
i was wondering, i'm looking to change my dials to white ones and was thinking of changing the bulbs (if poss) to blue ones, i was therefore wondering if anyone has done this and how hard it was and also what bulbs i'd need.
Many Thanks
Wayne.
Mackers
May 17, 2007
249
Bangor. N.Wales
i was thinking off the actuall, as i've bought all my rear bulbs off them and my front side lights too, not a single faliour in 2.5 yrs
Oct 17, 2006
2,141
Mid Wales
Isn't the illumination colour from a tinted plastic filter rather than the colour of the lamps? It certainly is on the heater controls. I think it'll be a bigger job than you'd think to change the illumination colour
Stan 24v
421
Blackpool
It is from some plastic film mate, yes. I did this on my Corrado, and its fairly easy, just a little time consuming.
You can remove the coloured film and replace with a coloured LED, or you can just replace the film with a different colour. You can get it from hoobycraft and the like.
Be sure to mark where the needle sits before you reomve it from the clocks though, otherwise it may over/under read. If its like my Corrado then although the needle sits of its rest, this isnt the furthest it wil travel. You may need to lift the needle over the rest, and see if it travle a bit further. this is where you need the mark.
dasmith83
Formerly "Dave FR PD130"
Jul 1, 2006
602
Kent
my old fiesta had a colour filter too, however my vauxhall corsa just had 501T twist fit bulbs which you can get a direct led replacement for...duno about the leon though...although after seeing the passat blue and red lights, they would be nice!
dasmith83
Jul 1, 2006
602
Kent
ah...u mean SMT (Surface MounTed leds)...they are a slaaaag to change via hand. I'll be leaving that then lol
Stan 24v
421
Blackpool
I would have thought that would only be on the dials themselves, whereas you "could" change the MFA bulbs if wanted.
Phoenix27
RIP Project Blueshift
Jan 17, 2010
838
Great Yarmouth, Norfolk
