Hi all,
I'm getting the above warning flash up on the dash, and then clear itself on restarting the car (65 plate Cupra 280 ST). I've read the codes with a handheld OBD2 scanner but nothing is being stored and/or cant be accessed by the code reader.
Does anyone know if other scanning tools would be able to access a different level of code storage or is this code only readable when the warning is still present? And, when I do read it, is the car smart enough to tell me which corner needs replaced? Cant generate the damn thing now I've got my code reader with me or I'd be able to answer for myself.
Also, the dampers all look fine, bit of surface rust after 75k but no leaks, DCC wiring seems intact but gonna give them a wobble to see if I can trigger it. Anyone know any method to try and trip the code? Other than strategically hit a pothole with each corner and hope it doesnt bend the wheels It's not yet bad enough to reveal itself under the old 'bounce each corner and see what doesn't dampen'.
Anyone encountered similar and and have any advice please?
