D/V & MAP sensor relocation....
str8ballin
211
Hi I have universal 2.5" pipes for my FMIC, I was thinking to relocate the D/V near to the inlet as I have to make a hole for it either there or in the original place near the turbo, but I also have to put the MAP sensor somewhere...
My question... is it better to put the MAP sensor close as possible the the Throttle Body or not?
Will having the D/V and MAP sensor by each other cause any problems??
I know the D/V should be after the sensor but just wondering if its ok to have them close by.
Hope this isnt a silly question! Many thanks in advance!
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
MAP Sensor wants to be somewhere between the IC and the TB, I doubt it will make any difference exactly where - physical mounting restrictions will probably be more relevant than anything else.
I wouldn't put them opposite each other, but it'll be fine if they're close.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Off Topic:
Feel: where the hell is that in your avater?! Looks like a huge steep hill with a large jump into the sea!
David.
