cuts out when cold?
gticupra123
146
berkshire
in the mornings when i use the car for the first 5 mins it will cut out if you dip the clutch, which is getting abit annoying now, then after 5 mins its fine. anyone know why? im guessing its a sensor but dont know which one. thanks
Kai_1600
Shallow
Dec 10, 2005
410
Manchester
What engine mate? I found that if i unplugged the sensor thats going into the airbox (maf?) then it caused the symptoms you described, suggests that might need a clean/new one
andyj
There's no F in Quality..
Coolant Temp Sensor could also be at fault.... if it's faulty, it could be telling the ECu that the engine is warm and therefore reduceing the fuel going into the cylinders..... when in fact the engine is cold, and requires increased fueling (i.e. automatic choke)
Sensor should be about £10 from GSF or ECP.
