I'm having issues with power at the minute, most times when i turn on the ignition, the climate control thing flashes for a bit and also with the headlights on, all the instrument lights are dimming with the stereo only at half volume on a small set up (400w amp)
I have checked the current draw and there is a contant 600mA being drawn on the 2nd big wire off the battery, (handbook says passenger cabin) when key is out and absolutely everything is turned off. The battery voltage reads about 11.8v...
What I want to know is, is 600mA the normal current draw for an ibiza?
I can stop the supply altogether by disconnecting the large black plug on the ecu under the dash (drivers side), I think this may be the BCM body/battery control module, or whatever seat call it.
Could somebody with access the ELSA possibly look up what that connector powers please?
Ive had the battery load yested and its fine, the alternator is ok too (14.4v)
