Cupra to Cupra R injectors!
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
please be gentle with me. Being new to the Seat and turbo world simultaneously,please bare / bear (???) with me.
What gains would be expected by changing the fuel injectors from standard cupra, to the cupra R ones?
Would it need the engine manangement to be altered to make any gains?
The car has the RSD 210 conversion.
Hope you can help, cheers
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
im 99% sure they are the same (ibiza) as its only a software change.
but, putting bigger injectors in requires you to check the pump can deliver the required flow and also that your map is requesting the fuel.
:cheers:
CupraR-Rog
Just Cruising...
Jul 19, 2003
2,291
West Somerset
Aren't the Ibiza Cupra's and Cupra R's identical under the hood apart from an engine re-map?
If so, no gains what-so-ever!
If you're talking LCR injectors though, then you'll need the engine re-mapped as otherwise you'll over fuel...
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
they're just stock ibiza 20vt / r ones - no different
part number is either
06A 906 031 AB
or
06A 906 031 BA
FYI - LCR ones are
06A 906 031 BC
tstrahonja
541
06A 906 031 AB
or
06A 906 031 BA
FYI - LCR ones are
06A 906 031 BC
06A 906 031 AB is very different than 06A 906 031 BA...BA is much shorter...
is it possible to use both of these on aqx engine?
tstrahonja
541
Yeah, it was a loong time ago...hopefully someone will clarify this cuz it seems that ive bought injectors that wont fit....
