Cupra R wider track?
jmrgtturbo
Is it true the cupra r has a wider track than the cupra? Is it just the front or both wheels and how many mm wider?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
all the wheels are 3mm more 'offset' making it a 6mm wider track all round
they were offset to clear the brakes.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
How are they offset mork? Through the wheels offset or track rod arms? Are the rear brakes the same as cupras...if they are why offset the rears aswell?
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
the wheel offset is different to the standard ibiza offset
track rod arms? how does that work?
same rear brakes
if the offsets were different front and back then you couldnt use back wheels on the front!
jmrgtturbo
Oh rite so if i just get some superturismo's with ET35 offset i will have the same 'wide track' as an R.
