Does anyone have, or know where I get the wheel alignment diagram for my cupra r st, as the tracking needs doing. All the tyre places iv been seem to think it's a leon cupra st and I don't want the negative camber to be changed.
150 in the UK. Unlike the R hatch, the R ST (like my Carbon Edition) wasn't really a limited edition in Europe. Yeah not every country got it, but they were just a different "trim" level in the likes of Germany and Spain etc, a bit like fords "Special editions" lol . This is why they didn't get numbered.Thanks Slicric
So that is at least 4 owners/cars, in only a few minutes of discussion and they only sold a maximum of 150 of our models!
There is definitely a safety and or warranty issue here for the manufacturer to deal with.
Its got me thinking,
Due to the extra parts required to be fitted to these cars, and knowing about how certain Seat cars had parts fitted at the port in the UK (The UK spec Mk 2 Cupra R had the diffuser and exhaust fitted at the port after arriving in England).
I'm wondering if these cars where built as standard at the factory. Then had the extra additional parts fitted later. With the expectation that PDIs should sort the wheel alignment out.
Just a thought anyway...
Unless I'm very much mistaken, 5F denotes that its a Mk3, not that its an ST. 1M being the Mk 1, and 1P being the Mk 2. Not aware of any specific model for the estate, although I believe part numbers may have a different denotation.Hi Damo H
Thank you for your detailed and prompt reply, obviously, you know what you are talking about.
I got Kwikfit to double-check that they had the settings for the correct car. As you know the 5F is the ST or estate body and the description does say Cupra, so it should be the correct car on their Hunter system. They said the database was up to date.
Does the description line on your Kwikfit Hunter reports state the same?
I really do think that these cars were never set up properly to reflect the minor improvements to the suspension and tracking.
The dealerships have both told me that they do not have access to any specific setup specifications for this model, hence they have put in a request to Seat UK.
Should I be suggesting to Kwikfit or any other Hunter tracking service provider to use the standard settings and then adjust specific parameters accordingly. If so would you know what they all should be for my model?
Many thanks
Mal
The thing is, the extra camber should be improving both handling and wear when pushing on.I've had my fronts replaced not that long ago as they were in the same state as all the above. I was just advised to take it easy on the corners and roundabouts
Yes 5F just denotes it's a Mk3 Leon, nothing to do with body type.Unless I'm very much mistaken, 5F denotes that its a Mk3, not that its an ST. 1M being the Mk 1, and 1P being the Mk 2. Not aware of any specific model for the estate, although I believe part numbers may have a different denotation.
Sadly I took the photo and have since misplaced the actual document itself, I thought it was with my service book. But I do remember checking it at the time to see if it matched and I wasn't concerned.
As for the figures. My understanding was that it was only the camber that should be different, although it may impact Castor. However Toe should be the same.
In theory Seat should be able to do a wheel alignment for you, there should be at least 3 versions. Cupra/Normal, Cupra R Hatch and Cupra R ST (Hatch didn;t have revised rear camber to my knowledge only front).
