Cupra R sound like a DIESEL at idle
May 13, 2007
1,017
Denmark
Hi all
Can any of you reckon this? Does your Cupra R sounds like a diesel at IDLE?
I'm tired of my girlfriend that keeps telling me "It sounds like a diesel", so now I want to know if thats normal?
Best regards, Thomas
lc_allan
Northern Monkey
Sep 15, 2006
3,389
As above mine only sounds rough on initial startup. First 5 seconds max then settles down.
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
The secondary Air Pump is quite noisey. My LC is a bit like that, especially when its particularly cold.
My mate has an A3 that has the same noise.
I don't think is serious, and the noise is definitely common. Although, if yours is excessively noisey. I'd reccoment getting it checkedm incase its gone or going!
I think thats probably what you are hearing....
Fastbaz
Fastbaz
Nov 26, 2006
91
west midlands
dont they have hydraulic valve adjusters it could be that they are the last in line while the oil pressure builds up from a cold start..... acouple of my old cars had these and from a cold start you could hear a light clanking noise for a couple of secs until oil pressure built up at the top of the engine... was alwasy okay after the engine had been started and run for a few minutes only seemed to happen when the car had been standing for some time like overnight ...just a thought now i have an excuse mine is a diesel (its smokey)
Jay20VT
The 'R' In CupRa
Jul 23, 2004
658
82
N.London
yeah, unless a tdi your car should not sound like that at idle certainly not at normal operating temperature. My Mk3 Golf GTI used to sound a little like that all the time at idle, turns out the timing belt was a little slack and slapping the casing, got it changed and all was well. Do get it looked at mate!
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
It's a trait of the VAG 1.8T engine...my old Mk4 Golf was particaularly prone to this.
The LC isn't so bad...especially with the new BF zorst ;)
