cupra r gauges
andy_tratter
161
Near JabbaSport ;)
on that vagcat link it shows a wiring harness, does this mean the standard cupra r gauges are electrical and just plug straight in without any extra mechnaical plumbing? prob sounds quite stupid as they're are only voltage and temp gauges so must run via the ecu, not like boost that actually needs to be measured through the dump valve??
chrissyscupra
i couldnt beleive the price, i also got told itd be 20 quid for 4 of they daft clips that hold ur engine cover on
yeah theyre elecrical,iv got 2 plugs where the guages should be
chrissyscupra
negative bud jus volt n temp guages,there sum pretty good threads bout pressure n boost guages n how to connect them
May 25, 2008
2,400
cambs
just ordered my gauge holder £8.81 :D and thats from the dealer i'm well shocked thought it would be more
May 25, 2008
2,400
cambs
ok just picked mine up it is 150mm x 150mm square with 2x 52mm holes part number 6k0 863 263 01c hope this helps £10.02 inc vat at 10% not 17.5% dont let them charge you the higher vat not till the new year anyway
Dan1.6
1.6 Power FTW!!!!!!!!
Sep 26, 2008
981
Chesterfield
thankyou mate your a star :)
May 25, 2008
2,400
cambs
BUMP ! any news on these mystery plugs ? had a gander on a dealers computer and it states something about a wiring harness?? do you need this to connect the two gauges??????
EvilKinevil
480
Scotland
right guys, got myself a gauge holder + gauges out an R.
have looked at the fitting guide (http://www.seatcupra.net/forums/showthread.php?t=72432) and that seems simple enough, just wondering if there is wireing already in-situ (2001 cupra) to just plug & play? as the gauges i got have a OE looking 4 pin plug
if not, i'm assuming I'm needing an oil pressure sensor? if so what sensor do I buy?, can someone point me in the right direction
cheers
(edit; I've got a spare gauge holder if anyones looking for one, its got a small split on the LHS and a scrape on the right, not bad but not perfect, will post to somebody UK that wants it for postage costs, PM if your interested)
