Cupra (Petrol) Boost Gauge
Engram
Does anyone have a picture that shows where you connect the pressure hose from a boost gauge to the Cupra 180 engine?
I've searched high and low but I've never found a picture for the petrol engine, only the diesel.
Thank you!
Engram
Hmmm.. now where is that shiny metal bit?!!
Thanks mate. I shall go and look at the car with that picture in hand and see if I can locate it!
Does the "green nipple" feature in the Cupra 180 engine? Or is that a diesel only thing?
Engram
Argh! I don't have something like that picture. Although I do have similar things.
Is the hose I need to intercept the one I've outlined in this picture?
Engine bay picture
I'm just guessing really. (As you might be able to tell!)
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
the picture that daniel owen has put up is of a forge recirculating valve007 so yes the vaccume pipe you have dotted is the correct one! should get a fittiment in your boast gauge kit to let you connect into it! T piece
gazjones
fr engine so the same and you can se the boost gauge tap off
