If you go to lucas they have a option on which you want i think
Can anyone recommend a pad which works with the wear sensor for a mk1 Leon Cupra 1.8T?:help:
Have a look at your local car parts shop, I got a full front axle set for £27.00 with wear sensor, which is pretty damn good. They are made by "Apec" which to be fair I've not heard of but the parts man said they are OEM standard, and they perform better than the ones that were previously on my cupra.
Hope that helps ;)
Edit: you could try www.vwspares.co.uk , they seem to be cheap but not sure of their service. Someone else might have experience working with them
Just cut the plug off the OLD pad, join the wire's and plug it back in, This will turn off the light and if your next set have the sensors then you can still plug them in.
Why do you want to keep the sensors ??? they dont always work.
