im not too sure on what timing its running as i bought the car with a re map on it, iv only got reciepts. it peaks to about 20psi and drops to about 13psi ,, where i live we can only get the 97 fuel unless i travel a bit. all the back pipes should be good as i re did them all when i removed the n75 valve and the secondary air pump
iv said a post on here before about it holds back for a second before boost and i still havnt sorted it so do you recon it could be related? i need to buy an air flow meter really
cheers
