If you mean drilled discs then you can buy them from most brake companies like EBC, Mintex, Brembo, Black Diamond etc. You need 312mm ones. Remember that they are more prone to cracking, being noisy, wearing down pads and costing 2-3 times more than a non-drilled disc. Drilled discs are usually only advised for race use..you might be better off with slotted/grooved discs but each to their own
