Cupra cut out after dv change?
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Ok, just changed my standard bosch jobbie to a piston type recirc. Took the car for a spin to check all was wee, it was, lovely. Until i came upto my road and turned the corner. Power steering went dead, looked at the clcoks and battery light was on? Turned ignition off, then strated as normal, and it fired up fine :confused:
Any ideas?
ZBOYD
Looking up at the stars!
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
I very much doubt its a problem related to the DV, as its got no electrical systems, on the Mk1 at least.
The first thing would be to check to see if you haven't snagged a wire or pulled something off while you've been fitting the DV.
If the car is just conking out, then double check the pipe work is properly seated and there are no huge air leaks.
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
What DV is it?
No idea, but came off an rs4, so shoudn't have any problems with the power
Only thing i didn't do was clamp the hose that goes to the top of the dump valve, as i didn't have a jubilee clip small enough. Could this be the cause?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Where the vacum pipe fits is the bit it fits to able to turn?
If not the hardness of the spring will dictate how it opens.
