Cupra Copper Nickel Brake pipe?
chrisbond69
chris bond
Jun 11, 2005
1,297
Cirencester, Glos
Ive gone to fit the brake pipe on my ibiza and the nuts rounded off the connection is so badly corroded that i need to buy new pipe and end nuts can someone tell me the size of the nuts and pipes i need to buy for my car and where you suggest getting good quality products from
thanks
chrisbond69
chris bond
Jun 11, 2005
1,297
Cirencester, Glos
just thought id make the new ones up considering the pipes only about 15 pound for three lines, if your making yours up could you tell me what size nuts and the pipe size of origionals please,
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
(M10) for the most and a couple of (M12) for the pipes from the master cyl to abs from memory
standard 3/16" (4.75mm) pipe
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
will try to but have snooker match on so if i do it means i lost badly :)
the nickel plated pipe is more durable (years lasting) but looks dull due to it's coating and the standard stuff looks 'nicer' if laid out clean and true
knowing how clean your truck is gonna be maybe a thought or two to getting steel or polished lines ?
and if you 'really' want ott i have larger bore sizes and fittings that may be useful for fuel pipe etc but i'm not so sure it's coated and useable with fuel
