crack5111
right. i recently changed the thermostat in my car as it took quite a while to get up to temperature and when it did it wouldnt keep constant.ever since i fitted the new one the cooling system has been pressurising up.so i decided to buy another one from seat as i thought the one i brought might not be opening or opening fully.ive fitted the genuine stat and its still the same. ive got water circulating through the top of the header tank but i dont know if its enough,its not overheating aswell so dont think its the water pump and its not using or loosing water.
what else could it be apart from headgasket?
could the secondary water pump cause any problems?
