fozzie
85
Hi there people,
Is it possible to fit mk3 Ibiza Cupra bumpers front and rear to a non-cupra model, and what sort of job is this?
any help will be much apprictaed.
Ben :)
Only differences is are the fog lights, which are costly from SEAT but you can get some spot fog lights which will fit in fine. Other than that if you have a 1.6 Sport you may have to shave a few .mm's off the lower air scoot and engine tray but thats about it.
Rear ones are hard to find, but you can make one just the same but cutting it out and use some plastic / hard rubber beading trim.
May sound stupid but can you get fogs on a non-Cupra that will work from the same fog light switch as the rear fog light?
Is there just a wire that needs connecting or is it a big job?
yeah you probably could get away with it, watch the fuse rating and power drain though, the rear wont have a big power rating compared to the fronts
