Cupra 300 ST DSG AWD vs Cupra 280 SC DSG Sub8 FWD - Back-to-back
Syndrome
68
Wiltshire
A while ago VW very graciously gave me a Golf R for a week after my Cupra 280 ate it's own engine and I did a rather lengthy post on a back-to-back comparison, clicky: http://www.seatcupra.net/forums/showthread.php?t=432400
Well the 280 SC DSG is going back at the end of the month and being replaced with a 300 ST DSG and as this is essentially a Golf R estate in drag I thought I'd do a similar brain dump.
First of all the timescales were a bit shorter this time around, about 30 minutes, so it won't be as verbose, however 95% of the comparison is the same as Golf R vs Cupra 280. I did this on a sunny clear day with a mix of twisty fast A-road, residential (for the speed bumps) and industrial areas (gotta love those fast roundabouts)
Spec of the cars:
280 SC FWD - Sub8 pack, DSG, ACC, 5" Nav, Bucket seats, Pano roof, SEAT sound and currently sat on Michelin PSS tyres at the front and PS3s at the rear.
300 ST AWD/4DRIVE - Standard brakes, DSG, ACC, High spec Nav, reversing camera, Bucket seats, standard roof, SEAT sound and was on Pirelli P Zero tyres (surprised me that one).
Driving/handling/comfort
I'll start with the obvious recycled statement from the Golf review, it takes off from the lights like a scalded cat, you can mash your foot down and get round the corner really fast with little thought or skill required, it is a very flattering car to drive fast, blah blah blah, however it isn't nearly as entertaining to drive as the FWD SC as once the thrill of the speed wears off you realise you are just a sack of meat along for the drive suggesting the general direction and speed to the car which does the hard work.
The first thing that struck me when performing a fast roundabout chicane is that there seems to be very little body roll from left to right or front to back in the ST whereas in the SC you can feel the weight being transferred as you accelerate, brake and turn. I put this down to a number of factors, the slight increase in length of the car, when you accelerate hard the Haldex diff pitches in thereby reducing the ferocity of the weight being transferred rearward, during hard cornering the diff in the SC quite aggressively puts power over to one wheel which I expect will lead to more weight being transferred to the opposite diagonal corner whereas the ST should be putting power to all 4 wheels and using the brakes to trim the line where appropriate.
Turn in wasn't as sharp as the SC and was a little lazier than the Golf R, length and weight will play some part in this but I'm guessing the diff in the SC is the main difference, that being said it was much less hassle to tweak the line mid corner in the ST; I'm interested to see what a slightly beefier rear ARB would do here!
Comfort wise, the shocks felt a little softer to me in all settings all though the rears felt slightly firmer in relation to the fronts, as it is an estate I guess the rear springs are stronger to cope with wardrobes and porky Labradors.
Acceleration when above 30-40mph didn't feel as fast as the SC and probably wasn't.
Exhaust sound externally seemed around the same level as the SC, although inside it seemed quieter, probably so you don't deafen any passengers while the SC and 5dr 300's probably sound a bit fruity.
The brakes were standard on the ST and felt softer than the Brembos on the SC and required a bit more pressure, some of this was probably down to the extra weight but guessing the majority was the size of the discs the the difference in caliper tech (sliding vs. floating); that being said they were still very effective.
Interior and nav
Major interior differences were the silver trim on the dash and steering wheel, DSG lever is a bit shorter and seems a little more offset, handbrake is now a button, cup holders have been rotated around 90 degrees and the white vinyl accents have been changed to carbon effect vinyl.
Regarding the interior the silver seems to brighten the interior a bit, can't say I care for the carbon effect vinyl as it looks cheap IMHO, other than that no real comments, it's still a lovely place to sit especially with the lovely bucket seats.
The navigation system looks much better and seems to have beefier hardware as it wasn't nearly as "ponderous" as the one in the SC. Display was nice and crisp however you have to tape the screen now to get the corner buttons up as the proximity sensor has gone.
In summary the ST with AWD didn't feel as visceral as the SC FWD car as there was none of sensation of weight transference when accelerating or cornering sharply and it required minimal skill to drive quickly, I suppose if I had to sum it up in a few words it would be "very competent but clinical".
Anyway, I'm taking the ex-demo I drove, I'm a pretty avid Scuba diver and the SC is a bit too restrictive (I have been in the boot twice now courtesy of 50kg+ worth of Twinset and the rather large loading lip), the Brembos on the Sub8 are pi**ing me off and as I am doing more miles in my new job I like knowing I have an AWD car when conditions are crap.
BreadlyBrown
281
Southampton
Nice write up. I do agree with you on a lot of points- I test drove the 300 ST and 290 ST and ended up going for the 290. Driving involvement was a factor but mainly the additional 5k premium for the 300 just didn't add up. (Both ex-demo so identical age/mileage and spec).
Sent from my SM-G361F using Tapatalk
Deleted member 103408
Like the first one nice write up and you have just helped me stay with my 280.
I love my current car simple because its got lots of power but you have to manage it, That is what gives me the smile when I go out for a drive and push it whist still being able to take the family out and put it in comfort mode.
Syndrome
68
Wiltshire
Cheers guys.
On the premium side the car I am taking has 5k on the clock and is less than £27k, so seem to have a pretty good deal as it is about £38k RRP and £32k on CarWow etc.
I do slightly regret not being told an estate was a few months away from being released when I ordered mine in July/Aug 2014 as I probably wouldn't be switching if mine was an ST.
bretth1974
561
Cheers guys.
Can't you find a decent 290 ST? Would be cheaper and more fun.
dieselface
647
Great write up - thanks!
I'm now in the market for my next car and these sorts of reviews will undoubtedly help me decide.
Enjoy the new car.
Syndrome
68
Wiltshire
Wanting a pretty specific spec, plus although the AWD is a bit boring in comparison it is a little more usable on a daily basis, something that suits me with the mileage I'll be doing.
If I want fun I can get the Caterham out of the garage, something that may happen a little more now.
Matt
124
10
Cheers guys.
Have you seen the deals for a new one on discounted-new-cars.com £26142 that's over £8k off
alper
108
7
Nice review that re-enforces my thoughts of switching to a ST 4Drive for both the space and usability of power. Sure we all like an agile, direct front-end but realistically, at least for me, there is no way to benefit from it during the most part of my commutes/drives unless driving like an idiot. This leaves me to have to do dedicated trips to roads that let the car shine and this is something I can barely do once or twice per month. It is very rewarding when it happens but in the typical everyday lives in the urban/sub-urban environments where most of us live, it can't happen nowhere often enough to keep me happy. So for the most part I am driving what feels like a "normal" car with some 360bhp that I can't easily put down and get occasionally frustrated and wondering what's the point having them anyway. That's where the 4Drive would shine. I'd take consistency of performance any day of the week and I couldn't care less about a few tenths lost on a track any more. That is not to say FWD is bad, it's just not the drivetrain I can make most out of, with such a strong car, at the present stage of my life.
SteA
226
61
Shrewsbury
Everyone has a different perspective on this. I used to see the point of 4wd in very poor weather conditions (although I still always chose RWD), but unless you are running more than 400 bhp, cars like the Mk3 Cupra are brilliant when just driving the fronts. Even when it's persisting it down they can already accelerate and generally travel at ridiculous pace for the public roads (far too quickly for the roads to be safe in reality). And on a super slippy wet racetrack they have brilliant traction. I might want different things to many drivers, I came from over a decade in RWD cars that wanted to kill you in the dry, so I've always valued throttle modulation and the feedback it gives you about grip levels :) Although that being said, I hadn't been able to persuade my wife out of her Quattro S3 because she did want to just stamp on the throttle and go when needed, without thinking, whatever the weather. After driving the Cupra, she has decided that the S3 and Quattro are redundant for her driving. I may also have a different view if I had a generic map? Mine is a custom map which could make a difference, although I plan to up the power more in the not too distant future...
