cryogenic brake discs
jok0212
Newbie
Mar 18, 2006
90
http://www.nitrac.co.uk/performancedisc.htm
anyone used them before??
got a quote from them under £280 all round for cupra r which i think its pretty good but he attached it with this diagram, any you guys know if thats the right size??
[/IMG]
fronts A.312.0 B.25.0 C.23.0 D.34.0 E.65.0 F.5+5
rears A.256.0 B.22.0 C.20.0 D.36.0 E.65.0 F.5+1
822
Poole
Seems a bit too cheap! Whats wrong with the Brembo's?
If you feel that they're not performing, its probably worth getting drilled discs and uprated pads?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
typical supplier presuming LCR uses same disk as LC which they dont.
vented rears also... 256mm and 323mm fronts on LCR
jok0212
Newbie
Mar 18, 2006
90
yeah thought it was the wrong size.
nothing wrong with the brembos, looking to upgrade the discs and pads and heard some good things about the cryogenic so thought might give it a try.
Aug 29, 2006
822
Poole
Yeah thats fair enough. See if they can quote you for the bigger discs on the front :)
jok0212
Newbie
Mar 18, 2006
90
just got a reply from them its going to cost over £200 for that size due to the suppliers they use dont have it and have to source from another supllier
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
cryo costs per kilo to do, so batching disks is how they do it.
plain disk run thru cryo process (or machined grooved disks)
supposed to give good wear characteristics. depends if you think you have poor wear characteristics now
