Hello all,
Just had a bit of a search on this and read the car's manual but still not 100% sure on a few CC related things.
I went in my uncle's Passat last night, which has CC, and I assumed it'd be the same in the Leon, but I'm not sure now.
Basically, does it have any kind of display? Can you set the speed using the stalk and it's displayed on the trip screen or anything, or is it all done by 'feel'?
So you turn it on, reach desired speed, say 70, click set and that's it? And if you increase (say to overtake) it'll go back to 70 once you let go? What about if you have to brake, will it speed up itself or does that disengage it (would make sense really)?
What impressed me about the Passat was while driving on the M25, as he came to a 50mph limit, he could set it down on the screen and the car would adjust itself, from 70, 60, 40, whatever it was on, subject to gearchanges (which I know disengage it) but this doesn't seem to be the case on the Leon? You'd have to slow down and redo it, at the risk of inprecision as well as you have to set it when you're there (might be 41 etc?)
Also, is there a light on the dash that comes on when it is operational?
Finally, what should I expect my local main dealer to fit it for, or is there anyone in the Surrey/Berks sort of area that would do it fitted for a good price?
My car is a 150bhp FR TDi by the way, which is apparently slightly cheaper to install as the wiring is there already I understand?
Thanks in advance for any advice
Rob
Rob
