Crazy Dials !! HELP
Razor
Inked Up Nation
Oct 12, 2008
830
Outside Belfast
www.bebo.com
Well 2 days ago, lost her and the front ended up against a curb
Was quite hard mayb about 15mph ( due to ice )
Last night I was about and noticed the petrol gauge going left to right lol
QUITE WORRYING
I stopped, then started again then the speedometer was stayin at 0 when driving !
Would the bump affected this ?
And how much will it cost to be fixed.
The rev meter is fine and today both speed and petrol gauges are fine too.
ian_cupra
you checked the fuses? might be one half out, so sometimes making connection and other times not
just a thought
ian_cupra
only a thought, might not be that :lol: but thats where i would start, then if there ok and its still doing it would be sticking vag-com on it
ian_cupra
yeah, usb to the port near the fuses, then can read the ecu
Razor
Inked Up Nation
Oct 12, 2008
830
Outside Belfast
www.bebo.com
Ok the same thing has happened again....
Last time, i filled up a full tank and that worked.
Jus tried it again but to no success.
Any one know what it could be?
Is it a electrical problem as its only the petrol and mph playing up ( right side )
The rpm and oil temp are fine !
:confused:
Jun 29, 2001
537
Surrey
Speed sensor?
When my speed sensor went, the speedo stopped working and the needle on the fuel guage went up and down when going round corners (unless the tank was full). It's an easy fix if that's the problem.
Jun 29, 2001
537
Surrey
I don't know mate, lol. I didn't change it myself but the mechanic that did it took him 30 seconds, literally!
